Forums Forums ROOFING FORUM UK Wet patches in the ceiling of upstairs room?
  • Wet patches in the ceiling of upstairs room?
    Posted by Neil Andrews on March 9, 2026 at 9:26 am
    We recently had a 2 storey extension completed, skimming completed 4 weeks ago.
    Since then we have noted few wet patches in the ceiling of upstairs room , that would take a couple of days to dry and then reappear with a week or 2 then again dry.
    Builder reassured us that’s it okay as long as it dries. However , just got the decorator now to start and they are quite worried about a potential leak from the roof vs possible minor piping leak.
    Any advice ? Should we ask the builder to cut the plasterboard and investigate further ? ( p.S builder have left now )
    Terry Davies replied 1 month, 2 weeks ago 11 Members · 10 Replies
  • 10 Replies
  • nigel-rowley
    March 9, 2026 at 9:27 am
    I would definitely look for the cause of the leak.
  • Peter Robinson
    March 9, 2026 at 9:28 am
    100% a leak , is your central heating boiler holding pressure,? Just wondering if you got a damaged pipe on your heating system
  • Raymond Foster
    March 9, 2026 at 9:29 am
    If it’s a leak why would it dry out ? Could be condensation?
    • Richard Tice
      because it stops raining
    • Roger Ellis
      March 9, 2026 at 9:30 am
      not this year
  • Samuel Coates
    March 9, 2026 at 9:31 am
    Leak, i would expect it to be roof related and dries out when it doesn’t rain. If it was boiler pipes then pressure would drop on boiler. Builder sounds like he’s fobbing off.
  • Jim Simpson
    Check the roof not the plasterboard often the leak is not where the water is coming through
  • Ste Laird
    March 9, 2026 at 9:32 am
    Definitely a leak. The builder saying its ok is him simply avoiding looking for it and fixing it.
  • Stuart William
    What’s above? Definitely looks like a leak, so I’d cut hole out to take a look. Very easy to repair hole after.
  • Terry Davies
    March 9, 2026 at 9:33 am
    If a flat roof..then may be a cold deck roof and has no ventilation, therefore when the heat from the house hits the roof condensation forms inside..creating a sweaty roof which then leaks into spot on the ceiling. Very common when theres no air flow.
