Forums Forums SOLAR FORUM UK Alternative to the Givenergy setup
  • Alternative to the Givenergy setup
    Posted by Keith Alexander on April 21, 2026 at 7:12 pm
    With the sad events around Givenergy, can we expect solar/battery advice to turn to “battery-agnostic inverter brands” as Google calls them? Are there reasons for not choosing these when specifying a new or replacement setup?
    Richard Ward replied 1 day, 15 hours ago 15 Members · 14 Replies
  • 14 Replies
  • Andy Clarke
    April 21, 2026 at 7:13 pm
    When I picked both my inverter/battery setups, I purposely picked a battery inverter combination that wasn’t tied to each other and I also try and stay away from anything with a fancy app/ai service to get the most out of the setup.
  • Olivia Johnson
    it’s the challenge with any specific manufacturers technology to either adopt or avoid the proprietary nature of that technology.
    Having been responsible for IT strategy and architecture for a number of years, I always leaned towards technologies that were known as Common Off The Shelf Technology (COTS) and away from technologies that had proprietary links.
    That said, the vast majority of battery systems are not proprietary as such other than they are packaged as an inverter and battery unit together.
  • Martin Shaw
    April 21, 2026 at 7:14 pm
    I have to admit paying a premium price for a system like Tesla or Sigenergy where the owner is effectively prevented from accessing most settings and they are only available via paying someone to do it remotely via a privileged login is very frustrating even though it’s unlikely these companies will go the same way
    If it wasn’t for the fact we get frequent power cuts and I want a gateway I am almost tempted to cancel my Sig install and go for something fully accessible like Sunsynk.
    • Michael Wright
      April 21, 2026 at 7:15 pm
      or Solax. Mine does full house backup . Used to get long power cuts every couple of months, Sods Law since install only used it once for 10 mins in the last 2 years
    • Dean Wade
      April 21, 2026 at 7:16 pm
      for reference Sunsynk doesn’t make the hardware or battery. It’s OEM from Deye for inverter. Battery is OEM elsewhere. Sometimes Sunsynk has different types or versions and they are not interchangeable.
    • Joseph White
      you can have full back up on sunsynk
    • Neil Elvidge
      April 21, 2026 at 7:17 pm
      could change for an inverter of equal size and export
    • Nick Dixon
      April 21, 2026 at 7:18 pm
      yes I probably could thanks, and will investigate, right now though I can’t because my install is via G99 fast track SGI2 and that does not allow islanding.
  • Sam Odell
    April 21, 2026 at 7:19 pm
    Its the chance you take with new market entrants, the Givenergys or Sigenergys could only be short lived and then little control for the average user when they are gone. This is where the older brands like Solis and Sunsynk excel. They have been around a while, lots of installation options and best of all….if it really goes bad you can fully configure most of them on the front panel.
  • Paul Doyle
    Sigenergy is now the fifth largest global residential BESS brand in the world. Just been approved for IPO listing this week and this will raise $640million for the company and values them at over $3billion.
    • Peter McMahon
      April 21, 2026 at 7:20 pm
      Pretty irrelevant (look at the history of business failures). I would not be doing business where e.g. I could not add a battery via myself of a 3rd party (not the installer)
  • Peter Robinson
    Surely some one can do a dalathe great for givenergy inverters to use standard pylontech batteries
  • Rich Murray
    April 21, 2026 at 7:21 pm
    I was already on the don’t buy proprietary solutions fence. There are plenty of options with properly documented full local control. Why would you take the risk?
  • Richard Ward
    could you suggest a shortlist? It might help when an installer quotes or recommends? Thanks.
