UK DIY Battery setup. looking to have a thread that will help me and others
my To be setup system will be .
2* SEPLOS Mason 48V DIY
2 * 48V 200A 16S Seplos BMS
2 * 58V 400A Fuse internal
all of above is part of the internal “selplos” system, all within the unit.
arrived Feb 2026
Built and working fine ~ some learning but all done in 12hr for both.
All disconnected and powered off until DNO approval and my logic for setup correct
So this is a 48v 200A2 * 16 MB31 314Ah Grade A Bundle (installed into 2* SEPLOS above)
giving home ~ 32kw1* SYNK-8K-SG05LP1
This is the popular UK Sunsynk Sun 8K ECCO Hybrid Inverter1* 3meter 50mm² cable RED. – will be cut to same length where needed
1* 3meter 50mm² c
Sorry, there were no replies found.
