Forums Forums SOLAR FORUM UK Thinking of getting battery storage
  • Thinking of getting battery storage
    Posted by Alan Smith on April 16, 2026 at 5:45 pm
    So I am thinking of getting battery storage. But just a bit confused. I have intelligent octopus Go, so it automatically set the schedule in the cheap night time. My question is. Will it still charge my car and move the cheap rate to my home battery storage at the same time. The battery I am looking at is the Fox ESS EP12 11.52kWh.
    Samuel Coates replied 1 hour, 25 minutes ago 10 Members · 12 Replies
  • 12 Replies
  • Tony Gammage
    April 16, 2026 at 5:46 pm
    Think of it this way , anything you have plugged in no matter what time will use electric. So yes it will charge anything but plugged in at cheap rate . It’s not selective as in your fridge and everything else turns off
  • Timothy Mayo
    Well you always get the cheap rate between 11:30am till 5:30am. So you would simply set the battery to charge between then.
    The battery wouldn’t be able to know when IOG is giving a cheap window, no.
    There is an app called Simple Solar with a SunSynk which actually can track when IOG is giving cheap windows, it’s around 95% accurate I’ve found. But either way you should be able to just charge overnight.
  • Chris Ward
    April 16, 2026 at 5:47 pm
    If you charge your battery between 11.30 and 5.30 it will be cheap. In addition the first 6 hrs of IOG scheduled car charging and any other load including batteries during that scheduled 6 hrs will also be cheap. Note If the 7th hour of car charging is within 11.30-5.30 car charging over 6 hrs won’t be cheap when iOG start to enforce their 6 hr fair use policy in the coming months.
  • Will Huges
    April 16, 2026 at 5:48 pm
    Just need to be aware that if IOG has a slot outside of 11.30-5.30, it may drain the battery.
  • Willie Baker
    The cheap rate 23:30 – 05:30 is when you charge the battery, home assistant can program the battery to charge outside those times when extra charging slots are awarded.
  • Tom Green
    April 16, 2026 at 5:49 pm
    This question gets asked a lot, on various forums and groups.
    The answer is Home Assistant. Once set up correctly, it’s 100% reliable and will get the best from your battery on IOG
    • Micheal Carter
      April 16, 2026 at 5:50 pm
      “the answer” isn’t Home Assistant – it is just one of many answers.
      If the EV charge point is wired correctly (split from the main house load by a Henley block) and the inverter CT is placed correctly then no automation is required
    • Tom Green
      April 16, 2026 at 5:51 pm
      Because it’s a lot more expensive. My average unit price over 12 months on IOG is likely to be well under 10p. Cosy makes sense if you don’t have an EV though.
    • Micheal Carter
      April 16, 2026 at 5:52 pm
      I get your point, however if the battery is sized correctly you don’t need to top up the battery charge during one of the dynamic slots. After all you do need to have the battery size for a full days capacity as it won’t always be topped up during the day and you don’t want to have to pay peak rate if the battery isn’t large enough
    • Tom Green
      Yes, that will work, but you’ll not be taking full advantage of the “bonus” IOG cheap rate slots.
      Putting the CT clamps for the charger and house battery in the correct places will prevent the car discharging the house battery, but it won’t make the house battery charge during the cheap slots.
      Home Assistant will do this.
      I reckon I’m saving an extra £200 to £300 a year by topping up my battery in the afternoon whenever I get a bonus slot.
      It’s effectively making my 12KWh battery work like a 20+ KWh battery at zero cost
  • Terry Wilson
    HA is likely best when on a dynamic tariff like Agile, but on IOG i have fixed times charge and discharge times & rates for the house batteries, admittedly I need to change the discharge times/rate 3 or 4 times a year. The only minor irritation is occasionally if I get an EV schedule with ‘additional slots’ is that my export then goes to the EV.
  • Samuel Coates
    April 16, 2026 at 5:53 pm
    Yes…and you will benefit..
    Just ensure you have a suitable sized battery to cover your daily winter use…
    Get the battery wired so that the car charger doesn’t see it…
