Forums Forums SOLAR FORUM UK Quote for solar and batteries from Heatable
  • Quote for solar and batteries from Heatable
    Posted by Darren Hall on April 9, 2026 at 4:05 pm
    So I’ve had a quote from Heatable for the following:
    13 x Longi solar Hi-Mo X10 Artist 485w panels
    Sigenergy 10kw hybrid inverter
    3 x Sigenergy BAT 10 batteries
    Gateway home pro
    Hypervolt 3 Pro 10m lead EV charger
    + all installation costs.
    Total: £18,500.
    I know that sits below the £1k per kwp and £500 per kWh but I was wondering if it’s a good quote or not.
    Nicholas Carey replied 1 day, 11 hours ago 14 Members · 21 Replies
  • 21 Replies
  • Zac Kendall
    April 9, 2026 at 4:07 pm
    Did they say why they have gone to Longi panels? Have messaged them as they always put the REA panels as being the best but not heard back as of yet. does that include bird proofing with only added costs to come as the scaffolding?
    • Darren Hall
      April 9, 2026 at 4:08 pm
      I saw the REA panels in the past, but I only saw Longi’s this time around.
      I didn’t question it and they seem to have good reviews.
      When I spoke to the installers, they all said the Longis were good too!
    • Steve Pennison
      Longi are the biggest panel suppliers in the industry and no1 globally, best out there and ones I’d choose personally, for inverter and batteries look at the GoodWe ESA G2, much better product and GoodWe are a far bigger more experienced company also
    • Zac Kendall
      April 9, 2026 at 4:09 pm
      Cheers mate,I got an online quote in the last two weeks and both panels were available although the rea ones where at the bottom and had to expand the image.
  • Samuel Coates
    On the high side
    Have a look around
  • Ron Glegg
    April 9, 2026 at 4:10 pm
    Its on the expensive side but without seeing the details on the installation I couldn’t say how much!
    • Darren Hall
      The price includes the scaffolding for two elevations, bird protection, all the paperwork and electrical work required for the house and garage.
  • Richard Harris
    April 9, 2026 at 4:11 pm
    Take a look at Longi performance as a rear back contact module with a 30/30 warranty . Also the ESG credentials . Longi is the only manufacturer with gold accreditation for the SSI (stewardship initiative )
    With rear back contact you get higher output power , a panel with no visible grid line and a higher efficiency . Over the life of the system with the longer warranty the investment will produce more energy . There are other aspects such as cell level optimisation and safety as to why installers are opting for longi.
    • Darren Hall
      Appreciate the information, so didn’t know that!
    • Richard Harris
      April 9, 2026 at 4:12 pm
      you’re welcome ! There are a few videos out on social media- check out the renewables podcast – I was on there a few weeks ago talking about Longi and the tech.
  • Peter Edwards
    a good quote should represent value for money – and to know that you need to compare it against your consumption.
    That size of battery would imply your house grid consumption, excluding EV charging is over 30kwh – is that correct? If so, what is the biggest consumer (ie is it a heat pump)
    • Darren Hall
      April 9, 2026 at 4:13 pm
      I have a heat pump now and generally high usage. Last years usage prior to heat pump but including the EVs was 12,500kwh.
      Based on the models, it brings my bills down drastically.
    • Peter Edwards
      April 9, 2026 at 4:14 pm
      ok, good to know it’s a heat pump. Do you think the heat pump is likely to be more than the EV’s, or can the EV’s be charged during the day? If so have a look at Octopus Cosy as it has 3 off-peak windows which could mean you can reduce the battery requirement by 2/3rds (ie 10kwh battery instead of 30kwh)
  • nigel-rowley
    I would suggestion looking aiko gen 3 panels, for what your getting seems high. Look at this group I posted my system to give you a comparison of my system cost to yours. Thank you
  • Neil Andrews
    April 9, 2026 at 4:15 pm
    Heatable are never the cheapest but you have a proper company with a reputation ! There is value in that in terms of risk reduction !
  • Eleanor Hall
    I obtained a quote from Heatables when I was selecting an installer, they quoted £482.90 per RERA 460w pannel installed. Separate price for inverter, battery, scaffold, and bird proofing. I almost asked if the panels are made of “fairy dust”!
  • Mike May
    April 9, 2026 at 4:16 pm
    That looks slightly pricey for the hardware used.
    I’m sure you’d be able to get Aiko panels and a Tesla Powerwall and expansion pack installed for similar money.
  • Darren Hall
    April 9, 2026 at 4:17 pm
    I’ll take a look and see the difference in prices. It was more expensive when I had this quote.
  • Matt Samuel
    It’s on the high side but it will be from a company like them. You’d save more than a Sunday night Chinese takeout by taking that spec and shopping around local. Plenty of installers in this group if you pop your postcode in and ask for direct comparisons
  • Michael Wright
    April 9, 2026 at 4:19 pm
    Get three quotes.
    Solar Cost Calculator | Compare Prices | Solar Systems £4000
  • Nicholas Carey
    April 14, 2026 at 8:12 am
    That actually looks like a pretty decent quote, especially considering you’re getting high-efficiency panels (around 23–24%) and a full hybrid setup with EV charger included . The battery size (30kWh) adds a lot of value, so it’s not just about £/kWp pricing. Overall it seems competitive, but still worth comparing a couple more quotes just to be sure.
