Forums Forums GARAGE CONVERSION FORUM UK I’ve created a garage conversion checklist
  • I’ve created a garage conversion checklist
    Posted by Alan Griffin on February 4, 2026 at 5:12 pm
    I’m part way through converting my garage and realised very quickly that there’s a lot more to it than just “no planning permission needed”.
    Building Control, insulation standards, fire separation, inspections at the right stages — it’s easy to miss something and end up redoing work.
    I started pulling everything into a simple checklist just so I could keep track of what needs checking and when, and it’s already saved me a couple of headaches.
    Posting this in case it helps anyone else who’s thinking about (or already started) a garage conversion — happy to answer questions based on what I’ve learned so far
    Step-by-Step Garage Conversion Checklist
    This checklist is designed to keep you on track from idea to sign-off.
    Before you start
    ☐ Confirm planning status
    ☐ Check permitted development rights
    ☐ Consider a Lawful Development Certificate
    ☐ Measure heights, boundaries, and floor levels
    Design stage
    ☐ Decide final room use
    ☐ Confirm insulation strategy
    ☐ Check roof build-up height
    ☐ Plan drainage and ventilation
    ⸻Before construction
    ☐ Notify Building Control
    ☐ Agree inspection stages
    ☐ Confirm fire safety requirements
    ☐ Confirm who is certifying electrics
    During the build
    ☐ Photograph insulation before covering
    ☐ Keep vapour barriers intact
    ☐ Avoid hidden joints
    ☐ Book inspections on time
    Completion
    ☐ Final Building Control inspection
    ☐ Completion certificate issued
    ☐ Retain documents for future sale
    Skipping steps here is how small projects become expensive problems
    Hope this helps
    I’ve actually turned this into a detailed guide with explanations and examples for each stage as a few people asked for it but this is the checklist and should help you loads
    Eren Bien replied 7 hours, 8 minutes ago 8 Members · 11 Replies
  • 11 Replies
  • Andrew Young
    February 4, 2026 at 5:13 pm
    Great post You’re absolutely right — garage conversions often don’t need planning permission, but Building Regulations are where most people get caught out (insulation, fire separation, floor levels, ventilation, inspections, etc.).
    Having a checklist is honestly one of the best ways to avoid costly rework later. We see a lot of projects where work has to be opened up again because something simple was missed early on.
    If anyone needs help sanity-checking their plans, drawings, or Building Control requirements before starting, happy to help or point you in the right direction.
  • Andy Clarke
    February 4, 2026 at 5:14 pm
    I haven’t started even planning mine yet, just thinking about it, but are these required if it is a detached garage and going to only be a room for like a summer house or a gym?
    • Amy Brown
      February 4, 2026 at 5:15 pm
      this is simply an outbuilding.
      So as long as the use remains incidental to the main dwelling, then no problems. A summer house or gym is fine.
      Only time, as with all garages, is if a condition on the planning permission says it must be kept for parking of vehicles.
    • Alexander Ward
      thanks! We are on a new build development, but I know my neighbours have converted theirs (the developer actually did it for them, I wasn’t aware they even offered that!) So I dont believe it would be a problem. Parking no issue as it is a long drive.
  • Andy Gay
    February 4, 2026 at 5:16 pm
    If you are doing it DIY then yes, you need to understand the building regulation requirements of which all the things you listed fall under.
    If paying someone, you are paying them to have that knowledge. The company that did ours fully dealt with building control from start to end.
  • Andy Clarke
    Im interested in your checklist. A builder helped me switch up and over doors for aluminium glazed ones. Gives me much better U value and stacks of light and I can still technically get a car in as I’ve not altered the width. But he didn’t set them back 20mm nor balance them. I had to get help from fensa installers to refit. Now that stage is good. Ground floor being used as a gym and workshop. Considering insulating floor with celotex and floating floor. Upstairs begun insulating rafters with 100mm celotex leaving air gap above.
    So much to learn.
    • Alan Griffin
      February 4, 2026 at 5:18 pm
      The checklist applies to both attached and detached garage conversions. The main differences for detached garages are things like planning rules, fire separation, insulation standards and how services are brought in, and those are all covered in the guide.
      If you’re happy to share, I can also sanity-check your specific setup.
    • Andy Clarke
      February 4, 2026 at 5:19 pm
      does that list work for a detached garage?
  • Alan Griffin
    February 4, 2026 at 5:20 pm
    Converting an integrated garage into a bedroom with a shower can definitely be done and doesn’t have to be too complex — as long as factors like ceiling height, drainage, insulation and fire separation are addressed.
    I’ve put together a step-by-step guide and checklist that covers this and more. It will walk you through all of this. If you’d like, here’s the link:
    https://martinpeat.gumroad.com/l/lercf
    Happy to answer any questions you have
  • Martin Peat
    March 19, 2026 at 7:31 pm
    That’s from a guide I put together glad it’s helping people. Happy to answer anything specific if you’re planning one.🙂
  • Eren Bien
    April 23, 2026 at 4:06 am
    This is really helpful and a solid reminder that a garage conversion is more than just putting up stud walls and plasterboard. A lot of people underestimate the Building Control side of things until they’re already mid-project.
    Your checklist covers the key areas that often get missed, especially insulation, ventilation, inspections, and keeping records for the final certificate. Those small details can save a lot of money and hassle later.
    Thanks for sharing this — it’ll definitely help anyone planning a conversion or already part way through one. The detailed guide sounds useful too, especially for first-timers trying to understand each step properly.
