In roof solar quotes
In roof system
Have now received 5 different quotes. I like a few of the companies i’ve met. The one i probably most wanted to work with has come back with an in-roof system at 6kwp. The other 4 have suggested on roof at 8kwp. All are around £11-12k for 8-17kwh batteries. All are reputable local companies so i’m not concerned around their credentials. All seem on the higher price bracket compared to what people here suggest you can get. But i’m not sure getting a 6th quote will be different. All would satisfy my current energy needs.
The reason for the post is around the In roof system. This was unexpected and is stated to be due to the roof pitch being 11 degrees. Its clearly added cost, reduced panel number and output/efficiency. The in roof system ROI is 14 years. The on roof systems are between 6-10 years.
Whilst ROI isn’t everything and clearly is a little artificial. The in roof system looks far less efficient. Is the pitch of 11 degrees really that big a deal and why has only 1/5 companies made it a problem?
