Forums Forums GARAGE CONVERSION FORUM UK Warm roof vs cold roof
  • Warm roof vs cold roof
    Posted by Martin Peat on March 23, 2026 at 8:56 pm
    Warm Roof vs Cold Roof – What’s Best for Your Garage Conversion?
    If you’re converting your garage, one of the biggest decisions you’ll face is whether to go for a warm roof or a cold roof. Get this wrong, and you can end up with condensation, poor insulation, and headaches down the line. Get it right, and you’ve got a space that’s comfortable all year round.
    Here’s a simple breakdown to help you decide 👇
    Warm Roof (Best Practice 👍)
    A warm roof places insulation above the roof structure, keeping the entire structure within the warm part of the building.
    This means:
    • Much better thermal performance
    • No cold voids = far lower risk of condensation
    • Meets building regs more easily
    • Keeps the space warmer in winter and cooler in summer
    The trade-off?
    It usually means raising the roof height slightly, which may require planning approval depending on your setup.
    Cold Roof (Cheaper but Riskier ⚠️)
    A cold roof has insulation between and below the joists, leaving a ventilated gap above.
    This can:
    • Be cheaper upfront
    • Avoid changing the roof height
    But:
    • Requires perfect ventilation to avoid condensation
    • More prone to damp and mould issues if done badly
    • Harder to achieve good U-values
    So which should you choose?
    For most garage conversions, a warm roof is the way to go. It’s more future-proof, performs better, and avoids a lot of common problems we see with cold roofs.
    A cold roof can work—but only if it’s detailed and ventilated properly. It’s not as forgiving.
    My advice:
    If you’re already investing in a conversion, don’t cut corners on the roof. It’s one of the most important parts of the build. I explain all this along with everything else you need to know in my Garage Conversion Guide-https://martinpeat.gumroad.com/l/lercf
    If you’re unsure what setup works for your specific garage, drop me a message—I’m happy to point you in the right direction 👍
    Martin Peat replied 1 month ago 1 Member · 0 Replies
  • 0 Replies
Sorry, there were no replies found.
