Forums Forums GARAGE CONVERSION FORUM UK Garage conversion floor insulation
  • Garage conversion floor insulation
    Posted by Martin Peat on March 23, 2026 at 6:17 pm
    Thinking about converting your garage or upgrading a room? Don’t overlook one of the biggest game-changers… floor insulation.
    It’s one of those things people often rush or try to save money on, but getting it right makes a huge difference to comfort, energy bills, and meeting Building Regs.
    Here are the main options to consider:
    • Rigid insulation boards (like PIR)
    A popular choice for garage conversions. Great thermal performance with minimal thickness, ideal if you don’t want to raise floor levels too much.
    • Insulated floating floor
    Insulation laid over the existing slab with chipboard or screed on top. Quicker to install and works well if you’ve got enough height to play with.
    • Suspended floor insulation
    If you’re building a new floor structure, insulation can go between joists. Good for airflow and moisture control when done properly.
    Every project is different, and the “best” option depends on your existing floor, ceiling height, and budget.
    If you want a full breakdown of costs, build-ups, and what works best in real UK garage conversions, I’ve put everything into a simple step-by-step guide.
    Comment below with your questions, thoughts and ideas or click the link for Garage Conversion Guide-https://martinpeat.gumroad.com/l/lercf
    Best Hommes replied 1 month ago 2 Members · 1 Reply
  • 1 Reply
  • Best Hommes
    March 26, 2026 at 5:50 am
    For garage conversion floor insulation, the usual method is:
    DPM on the existing concrete slab
    PIR/XPS insulation boards tightly fitted
    Taped joints to avoid cold bridging
    18–22mm T&G chipboard/OSB on top
    Edge insulation around the perimeter
    It’s the most common way to meet Building Regs without digging out the floor. Just make sure to check height levels and damp before starting.
    More info you can visit my garage conversion services in wolverhampton.
