Forums Forums BUILDING FORUM UK Can I put bi-fold door in this wall?
  • Jessica Moore
    January 2, 2026 at 1:04 pm
    It’s single skin wall. The blocks add stability. A structural engineer will be able to design something for you.
  • Leonard Ross
    January 2, 2026 at 1:05 pm
    You can put bifolds anywhere mate. It’s how you buy out any structural problems installing them.
    Most go along a gable end because it requires just 1 support steel and 2 standard pad supports.
    You can layer supporting RSJ’s but it obviously requires stronger pillars and bigger steels.
    Going along there will be fine. But it’ll need a steel above and potentially a bigger pad support by the looks of the photo.
