MMOexp-POE: Why Delve Is the Best Currency Farm After the 3.28 Update
Delve has always been one of the most misunderstood mechanics in Path of Exile. Most players either ignore it entirely or assume it’s only for extreme endgame “deep delving” builds that require mirror-tier gear. But after the 3.28 update, Delve has quietly become one of the most efficient low-investment currency strategies in the entire game-especially through shallow darkness farming.
This guide breaks down how Delve actually works, why shallow delving is so profitable, and how you can consistently generate currency without needing a top-tier build.
Deep Delve vs Shallow Delve: Two Completely Different Games POE currency
Before anything else, it’s important to separate Delve into two distinct systems:
Deep Delve
Deep Delve is the extreme endgame version of the mechanic. It scales infinitely in difficulty and quickly becomes one of the hardest environments in Path of Exile. At high depths, monsters become incredibly tanky and lethal, requiring specialized builds and near-perfect optimization.
This is not what most players should focus on.
Shallow Delve
Shallow Delve, on the other hand, is where the real opportunity lies.
Instead of pushing depth, you stay in a moderate range and focus on:
Fast node clearing
Exploring side paths
Farming fossils, resonators, and chests
Engaging with darkness mechanics
This version of Delve is:
Low investment
Extremely fast
Highly repeatable
Surprisingly profitable
And most importantly-it doesn’t require a broken build to work.
Why Delve Is So Profitable in 3.28
The 3.28 update significantly changed fossil acquisition. Previously, fossils could be farmed efficiently in other mechanics, but now:
Fossils primarily come from Delve again.
This single change reshaped the entire economy.
Fossil Value Explosion
Fossils now range widely in value:
Cheap fossils: ~5-10 chaos
Mid-tier fossils: 10-60 chaos
High-value fossils: 1+ divine
Because Delve is the main source again, every fossil node becomes meaningful currency.
Resonators Add Extra Value
Resonators are another major income source:
Common resonators: small chaos value
Prime resonators: up to 1+ divine
They drop frequently enough that Delve farming often competes with top-tier mapping strategies.
The Core Loop of Delve
Delve is built around a simple system:
1.You follow a mine cart through nodes
2.The cart provides light
3.Outside that light is darkness, which deals stacking damage over time
4.You move from node to node collecting rewards
At first glance, it looks like a straightforward escort mechanic.
But the real mechanic is darkness.
Darkness Farming: The Hidden Profit Engine
Darkness applies stacking damage over time when you leave the cart’s light radius. Most players avoid it completely-but that’s a mistake.
In shallow Delve, darkness becomes a loot-rich exploration zone.
What Darkness Farming Actually Is
Instead of sticking to the main path, you:
Run into dark side corridors
Break hidden walls
Open chests
Loot fossil caches and resonators
Return to the cart for safety
You repeat this constantly between nodes.
The cart acts as a reset button-step back into light and your darkness stacks disappear.
Why You Don’t Need a Strong Build
One of the biggest misconceptions about Delve is that it requires a tanky build.
In reality, shallow Delve rewards:
Speed
Recovery
Mobility
Awareness
You don’t need to survive everything-you just need to:
Enter darkness briefly
Loot quickly
Return to light
Knowledge and efficiency matter far more than raw power.
Best Build Type for Shallow Delving
While many builds can work, one stands out:
Toxic Rain Pathfinder
A classic choice for a reason:
High sustain through life recovery
Excellent movement speed
Built-in phasing
Strong damage over time
Extremely safe in darkness zones
This build allows you to comfortably dip into darkness, loot quickly, and escape without risk.
Fossil Nodes: The Core Target
Delve is structured around reward nodes, and fossil nodes are the most important.
There are two main types:
1. Smuggler’s Stashes
These contain general fossil pools.
5-12 fossils per node
Average value still strong
Very fast clears
Even “low-value” fossils remain profitable.
2. Biome-Specific Fossil Nodes
These are where real currency spikes happen.
Examples include:
Hollow Fossil nodes (Crystal Spire)
Faceted Fossil nodes (Magma Fissure)
Fractured Fossil nodes
Some of these guarantee high-value fossils worth 1+ divine each.
A single lucky node can completely outvalue multiple maps.Bosses in Delve: Hidden Jackpot Encounters
Delve includes three major bosses:
The Crystal King
Ahuizotl the Blind
Kurgal the Blackblooded
These bosses drop:
Unique Delve items
Valuable rings and amulets
Special crafting bases
High-value chase items
Notable Drops
Doryani’s Machinarium
Often worth ~20 divine
Required for challenges
Only obtainable in Delve
The Aul’s Uprising
Highly variable rolls
Extremely valuable in the right builds
Bosses are fast, easy, and highly rewarding compared to their difficulty.
Special Delve-Only Items
One of Delve’s most unique features is exclusive item generation.
You can find:
Fractured Delve rings
Curse-on-hit bases
Elemental conversion modifiers
Minion-focused gear
These items can drop already fractured, making them incredibly valuable crafting bases.
A single example:
Fractured Despair-on-Hit ring
Worth 10-15+ divine depending on rolls
These cannot be obtained reliably anywhere else in the game.
Azurite: The Delve Currency System
Azurite is another key resource.
You use it to upgrade your Delve capabilities:
Light radius
Darkness resistance
Sulphite capacity
Flare and dynamite limits
Early progression should focus on:
1.Sulphite capacity
2.Light radius
3.Darkness resistance
Later, excess Azurite is best spent on:
Resonators
Crafting materials
Sulphite and Map Strategy
Delve requires Sulphite to enter nodes.
With the right atlas setup:
You can generate massive Sulphite per map
Sulphite veins scale with map quantity
Certain atlas passives multiply returns
Some strategies can generate:
3,000-30,000 Sulphite per map
This determines how much Delve you can run per session.
How a Darkness Run Actually Looks
A typical run looks like this:
1.Move from node to node
2.Check side corridors
3.Break hidden walls with dynamite
4.Loot fossil caches
5.Return to cart
6.Repeat
You ignore most enemies unless necessary.
The goal is not combat-it’s efficiency.
Occasionally, you’ll find:
Fossil clusters
Resonator chests
Currency drops
Rare Delve uniques
Even small finds add up quickly.
Node Priorities in Shallow Delve
Not all nodes are equal. Priority targets include:
High Priority
Fossil nodes
Resonator nodes
Biome-specific fossil areas
Boss encounters
Medium Priority
Currency nodes
Minion-related fossil zones
Chaos/lightning/fire/cold item nodes
Low Priority
Generic weapon/armor chests
Essence or beast nodes
Random filler encounters
Depth Recommendations
If you’re starting Delve:
Depth 1-145: learning phase
Depth 200-300: optimal farming zone
Depth 300-400: increased difficulty, higher rewards
400+: begins to require strong builds
Most profitable shallow farming happens well before extreme depths.
Final Thoughts
Shallow Delve in Path of Exile 3.28 is one of the most underrated currency strategies in the entire game.
It succeeds because it rewards:
Knowledge over gear
Speed over power POE orbs for sale
Exploration over combat
Efficiency over investment
With fossils back in Delve’s core economy and resonators still highly valuable, every run has meaningful upside.
You don’t need deep Delve, mirror-tier builds, or complex setups. You just need to understand how to move through darkness efficiently and know what to look for.
For many players, this may end up being one of the best league-start or mid-league farming strategies available.
Sorry, there were no replies found.
