Forums Forums GARAGE CONVERSION FORUM UK MMOexp-POE: Why Delve Is the Best Currency Farm After the 3.28 Update
  • MMOexp-POE: Why Delve Is the Best Currency Farm After the 3.28 Update
    Posted by Chunzliu Chunzliu on April 29, 2026 at 2:39 am
    Delve has always been one of the most misunderstood mechanics in Path of Exile. Most players either ignore it entirely or assume it’s only for extreme endgame “deep delving” builds that require mirror-tier gear. But after the 3.28 update, Delve has quietly become one of the most efficient low-investment currency strategies in the entire game-especially through shallow darkness farming.
    This guide breaks down how Delve actually works, why shallow delving is so profitable, and how you can consistently generate currency without needing a top-tier build.
    Deep Delve vs Shallow Delve: Two Completely Different Games POE currency
    Before anything else, it’s important to separate Delve into two distinct systems:
    Deep Delve
    Deep Delve is the extreme endgame version of the mechanic. It scales infinitely in difficulty and quickly becomes one of the hardest environments in Path of Exile. At high depths, monsters become incredibly tanky and lethal, requiring specialized builds and near-perfect optimization.
    This is not what most players should focus on.
    Shallow Delve
    Shallow Delve, on the other hand, is where the real opportunity lies.
    Instead of pushing depth, you stay in a moderate range and focus on:
    Fast node clearing
    Exploring side paths
    Farming fossils, resonators, and chests
    Engaging with darkness mechanics
    This version of Delve is:
    Low investment
    Extremely fast
    Highly repeatable
    Surprisingly profitable
    And most importantly-it doesn’t require a broken build to work.
    Why Delve Is So Profitable in 3.28
    The 3.28 update significantly changed fossil acquisition. Previously, fossils could be farmed efficiently in other mechanics, but now:
    Fossils primarily come from Delve again.
    This single change reshaped the entire economy.
    Fossil Value Explosion
    Fossils now range widely in value:
    Cheap fossils: ~5-10 chaos
    Mid-tier fossils: 10-60 chaos
    High-value fossils: 1+ divine
    Because Delve is the main source again, every fossil node becomes meaningful currency.
    Resonators Add Extra Value
    Resonators are another major income source:
    Common resonators: small chaos value
    Prime resonators: up to 1+ divine
    They drop frequently enough that Delve farming often competes with top-tier mapping strategies.
    The Core Loop of Delve
    Delve is built around a simple system:
    1.You follow a mine cart through nodes
    2.The cart provides light
    3.Outside that light is darkness, which deals stacking damage over time
    4.You move from node to node collecting rewards
    At first glance, it looks like a straightforward escort mechanic.
    But the real mechanic is darkness.
    Darkness Farming: The Hidden Profit Engine
    Darkness applies stacking damage over time when you leave the cart’s light radius. Most players avoid it completely-but that’s a mistake.
    In shallow Delve, darkness becomes a loot-rich exploration zone.
    What Darkness Farming Actually Is
    Instead of sticking to the main path, you:
    Run into dark side corridors
    Break hidden walls
    Open chests
    Loot fossil caches and resonators
    Return to the cart for safety
    You repeat this constantly between nodes.
    The cart acts as a reset button-step back into light and your darkness stacks disappear.
    Why You Don’t Need a Strong Build
    One of the biggest misconceptions about Delve is that it requires a tanky build.
    In reality, shallow Delve rewards:
    Speed
    Recovery
    Mobility
    Awareness
    You don’t need to survive everything-you just need to:
    Enter darkness briefly
    Loot quickly
    Return to light
    Knowledge and efficiency matter far more than raw power.
    Best Build Type for Shallow Delving
    While many builds can work, one stands out:
    Toxic Rain Pathfinder
    A classic choice for a reason:
    High sustain through life recovery
    Excellent movement speed
    Built-in phasing
    Strong damage over time
    Extremely safe in darkness zones
    This build allows you to comfortably dip into darkness, loot quickly, and escape without risk.
    Fossil Nodes: The Core Target
    Delve is structured around reward nodes, and fossil nodes are the most important.
    There are two main types:
    1. Smuggler’s Stashes
    These contain general fossil pools.
    5-12 fossils per node
    Average value still strong
    Very fast clears
    Even “low-value” fossils remain profitable.
    2. Biome-Specific Fossil Nodes
    These are where real currency spikes happen.
    Examples include:
    Hollow Fossil nodes (Crystal Spire)
    Faceted Fossil nodes (Magma Fissure)
    Fractured Fossil nodes
    Some of these guarantee high-value fossils worth 1+ divine each.
    A single lucky node can completely outvalue multiple maps.Bosses in Delve: Hidden Jackpot Encounters
    Delve includes three major bosses:
    The Crystal King
    Ahuizotl the Blind
    Kurgal the Blackblooded
    These bosses drop:
    Unique Delve items
    Valuable rings and amulets
    Special crafting bases
    High-value chase items
    Notable Drops
    Doryani’s Machinarium
    Often worth ~20 divine
    Required for challenges
    Only obtainable in Delve
    The Aul’s Uprising
    Highly variable rolls
    Extremely valuable in the right builds
    Bosses are fast, easy, and highly rewarding compared to their difficulty.
    Special Delve-Only Items
    One of Delve’s most unique features is exclusive item generation.
    You can find:
    Fractured Delve rings
    Curse-on-hit bases
    Elemental conversion modifiers
    Minion-focused gear
    These items can drop already fractured, making them incredibly valuable crafting bases.
    A single example:
    Fractured Despair-on-Hit ring
    Worth 10-15+ divine depending on rolls
    These cannot be obtained reliably anywhere else in the game.
    Azurite: The Delve Currency System
    Azurite is another key resource.
    You use it to upgrade your Delve capabilities:
    Light radius
    Darkness resistance
    Sulphite capacity
    Flare and dynamite limits
    Early progression should focus on:
    1.Sulphite capacity
    2.Light radius
    3.Darkness resistance
    Later, excess Azurite is best spent on:
    Resonators
    Crafting materials
    Sulphite and Map Strategy
    Delve requires Sulphite to enter nodes.
    With the right atlas setup:
    You can generate massive Sulphite per map
    Sulphite veins scale with map quantity
    Certain atlas passives multiply returns
    Some strategies can generate:
    3,000-30,000 Sulphite per map
    This determines how much Delve you can run per session.
    How a Darkness Run Actually Looks
    A typical run looks like this:
    1.Move from node to node
    2.Check side corridors
    3.Break hidden walls with dynamite
    4.Loot fossil caches
    5.Return to cart
    6.Repeat
    You ignore most enemies unless necessary.
    The goal is not combat-it’s efficiency.
    Occasionally, you’ll find:
    Fossil clusters
    Resonator chests
    Currency drops
    Rare Delve uniques
    Even small finds add up quickly.
    Node Priorities in Shallow Delve
    Not all nodes are equal. Priority targets include:
    High Priority
    Fossil nodes
    Resonator nodes
    Biome-specific fossil areas
    Boss encounters
    Medium Priority
    Currency nodes
    Minion-related fossil zones
    Chaos/lightning/fire/cold item nodes
    Low Priority
    Generic weapon/armor chests
    Essence or beast nodes
    Random filler encounters
    Depth Recommendations
    If you’re starting Delve:
    Depth 1-145: learning phase
    Depth 200-300: optimal farming zone
    Depth 300-400: increased difficulty, higher rewards
    400+: begins to require strong builds
    Most profitable shallow farming happens well before extreme depths.
    Final Thoughts
    Shallow Delve in Path of Exile 3.28 is one of the most underrated currency strategies in the entire game.
    It succeeds because it rewards:
    Knowledge over gear
    Speed over power POE orbs for sale
    Exploration over combat
    Efficiency over investment
    With fossils back in Delve’s core economy and resonators still highly valuable, every run has meaningful upside.
    You don’t need deep Delve, mirror-tier builds, or complex setups. You just need to understand how to move through darkness efficiently and know what to look for.
    For many players, this may end up being one of the best league-start or mid-league farming strategies available.
    Chunzliu Chunzliu replied 3 hours, 30 minutes ago 1 Member · 0 Replies
  • 0 Replies
Sorry, there were no replies found.
