New solar install payback?
I’ve currently got a DIY installed 16kwh battery and a small 2kwh of solar panels (shed mounted). I was planning on have more solar installed on the house by an installer to give me a MCS certificate to allow export.
Payback was always going to be questionable as I’ve ran on about 96% off peak tariff over winter on IOG. Most my saving was going to be from summer exports at 15p which has dropped by 20%. With IOG now dropping to 3.5p/4p it’s making spending £4-5K very hard to justify.
I know it’s always going to be based on tariff availability but if you have an EV is solar even worth it anymore or should you just have battery only
