Forums Forums HOME EXTENSION FORUM UK Building above garage that is attached to the house
  • Henry Smith
    January 12, 2025 at 5:57 pm
    First thing to do is do a test hole to see what the footings are like as the outer skin is not load bearing you can do it a couple of ways without knocking it down we’ve dug a trench and mass filled with concrete to take the inner skin we’ve also put Rsjs in to build off
  • Edward Jackson
    January 12, 2025 at 5:58 pm
    Knock it down and start again, it might be the same cost depending on the ground, but will be far quicker and easier.
  • Malc Nuneam
    January 12, 2025 at 6:01 pm
    Cost would be a 6 figure sum. You have to bear in mind the cost of demolition of the garage and clearing the existing foundations preparing groundworks for new foundations (deeper for two storey so more excavations, drainage etc) even before you have got to DPC level you would have spent £15-£20k at this point.
  • James Adams
    January 12, 2025 at 6:04 pm
    Get a survey done and employ a structural engineer, otherwise, you are treading a minefield Builders will harp on about how to go about the work and they Havnt seen the job or done their site survey and then they will price it and Balls it up and still want paying
