Forums Forums ARCHITECTURAL FORUM UK Architects quotes in North Yorkshire
  • Architects quotes in North Yorkshire
    Posted by William Platt on March 22, 2026 at 1:41 pm
    Hi all — just looking for a sanity check from anyone who’s recently done a loft conversion and/or side extension (North Yorkshire area).
    Here’s the quote I’ve been given for planning, drawings, and structural work:
    Side Extension (over 3m deep, so full planning needed):
    Planning app fee: £528 (to council)
    Drawings & application handling: £850
    Building regs fee: £712
    Construction drawings & structural calcs: £1,950
    Total: £4,040
    Loft Dormer (doing Lawful Development Cert route):
    Application fee: £290
    Drawings: £850
    Building regs fee: £654
    Construction drawings & structural calcs: £1,850
    Total: £3,544
    Grand Total for Both: £7,584
    If I combine the planning applications, that comes down to £7,094 — saving about £500.
    Question is: Does this sound fair/reasonable for what’s being offered — or am I paying over the odds?
    Appreciate any thoughts or comparisons from those who’ve recently done similar work!
    Ron Glegg replied 3 weeks, 3 days ago 14 Members · 13 Replies
  • 13 Replies
  • William Taylor
    March 22, 2026 at 1:42 pm
    Seems reasonable to me.
  • William Allen
    March 22, 2026 at 1:43 pm
    You need something to compare, always best to get a number of quotes then you know your range. These do seem reasonable to me but if you have nothing to compare then I would ring around a couple of places.
  • Chris Ward
    March 22, 2026 at 1:44 pm
    Depending on area you are not far off. As said elsewhere planning/ building regs fees are statutory so the only variable is architectural drawings. I would charge £1175 fixed for this service
  • Warren Hughes
    Why can’t both sets of cakcs and drawings be done at same time under same scheme
  • Victoria Carter
    March 22, 2026 at 1:45 pm
    Technically depending on increased cubic meters added you might not need planning for the loft
  • Stuart Tween
    Those all seem about right to me.
    You might be able to get the SE calls cheaper. I find they vary considerably.
  • Tom Green
    March 22, 2026 at 1:46 pm
    It’s not too bad, I would normally be about £1100 for survey planning drawings but the 2nd application would be much cheaper as the survey would have already been done. Having said that I’d probably submit as one application.
    Construction drawings seems reasonable, engineers I tend to use would be around £1200. But would expect to be a little cheaper if all works where done at once.
  • Thomas Walker
    It’s Always about getting at least 2 quotes.
    Compared to South Wales those prices are expensive.
    Sure their service is excellent though
  • Stephen Marsh
    March 22, 2026 at 1:47 pm
    These fees seem reasonable and, as always, it depends on the practice. Personally, I would have charged a bit less, as I’m an Architectural Technologist and for a small-scale development like this, it’s often not essential to appoint a full architect.
    For a complete package, including planning application fees, my charge would typically be under £4,500. It might be worth getting a few more quotes to see how much prices vary depending on your local area.
  • Matthew Totty
    March 22, 2026 at 1:48 pm
    Wait til every trade on the planet takes your pants down only gets worse
  • Simon Henderson
    Seems about the going rate in 2026
  • Sam Johnson
    March 22, 2026 at 1:49 pm
    Blimey .
    Mine was £1350
    For architect plus structural and before someone moans that was a cowboy price , my plans got approved by the council within three hours on fast track.
    (Back in March 2025)
  • Ron Glegg
    March 22, 2026 at 1:50 pm
    Prices pratically doubled from 1st April, if you cost that in, its not to bad.
