Forums Forums GARAGE CONVERSION FORUM UK Gas meter in a garage conversion?
  • James Adams
    December 26, 2025 at 4:34 pm
    You can get it moved but it might have to be done by Cadent and they have a wait list. When we enquired it was several months and the cost estimate was a couple of grand.
  • Dean Wade
    Can either box it in or build a full cupboard around it, can use the rest for storage.
    We have the gas meter, consumer unit and boiler on our garage conversion
  • Nicholas Wood
    December 26, 2025 at 4:35 pm
    If you going through a proper way through building control you will have to move it outside where if there is the need for an emergency -eg leak or fire services they have to turn it off before entering the building -not all houses are like this but they are trying to do to all projects that require building control
  • Oliver Smith
    Can stay where it is just put a cupboard round it?
  • Patrick Hughes
    December 26, 2025 at 4:36 pm
    If you can’t box it in then move it but from memory your supplier has to move it and the incoming feed but it’s expensive!!!
  • Paul Moore
    December 26, 2025 at 4:37 pm
    Stay where it is and put a box around it that’s what we did
  • Peter Edwards
    Mine was boxed in and because of the thickness of good insulation it hardly stuck out. It’s very expensive to move it outside. My conversion was through permitted development
  • Rachael Hughes
    December 26, 2025 at 4:38 pm
    We got ours moved to outside. It’s was around £800
