Thinking about converting your garage in 2026?
Thinking About Converting Your Garage in 2026? Here’s What It Might Cost!
Decided to post this after seeing a few people commenting on questions and fears they have about converting their garage.
If you’re like many homeowners wondering whether that under-used garage could be transformed into extra living space – office, bedroom, playroom or something else – here’s a quick snapshot of what you might expect to spend in the UK this year
Typical cost range: Most garage conversion projects fall roughly between £10,000 and £20,000 for a standard single garage – depending on size finish level and what you’re planning to use the space for. Bigger or more complex projects (e.g., adding a bathroom, kitchen or high-end finishes) can push the price £20,000+.
Double garages. If you’re converting a double garage or attaching extra space costs can often be £20,000 to £40,000+ – especially if you’re creating something more luxurious.
What influences the cost?
Size and layout of the garage
Insulation, electrics & plumbing work
Level of finish and fixtures
Whether you need new doors/windows or structural changes
Building regulations compliance fees
Good to know. Most garage conversions don’t require full planning permission (especially if the external structure doesn’t change) but building regulations approval is usually needed to make the space legally habitable and that cost (and paperwork) should be factored into your budget.
If you’re seriously considering this the best next step is to get a few detailed quotes every garage and plan is different.
Thinking about doing one yourself or have recent conversion experience? Drop your tips or questions below!
