Forums Forums LOFT CONVERSION FORUM UK Struggling to get started with our loft conversion
  • Struggling to get started with our loft conversion
    Posted by Mia Thomas on February 1, 2025 at 11:45 am
    Hi knowledgeable people!
    My partner and I are struggling to get started with our loft conversion. We know 80% of what we want but struggling to work out which professionals to ask and how to find out costs for the non standard bits.
    Are there good books/websites you’d recommend for reading up on which professionals should do what, what to line up before starting, working out estimates of what different aspects should roughly cost?
    Tim Miller replied 2 weeks, 2 days ago 7 Members · 6 Replies
  • 6 Replies
  • Daniel King
    February 1, 2025 at 11:46 am
    I can definately help you here and flag up a few things to add to your check list of things also to watch out for.;
    – Assuming you have the head height,?
    – Done any survey of the existing roof structure to ensure integrity?
    – Identified what type of loft conversion you are looking for to do?
    – Check if it is within permitted planning
    – Not a conservation area?
    – Party wall agreements needed if you are in a terraced home.
    An architect would be the natural step as I always think of it like the lego box, so many people start costing with just the picture on the box but you really need the instructions (building reg drawings) before you can even start to cost, establish the right ventilation, type of insulation, airflow, materials quantities and how everything fits together i.e. scaffolding, glazing e.t.c e.t.c
    You will without a doubt find any builder that costs without these detailed drawings will caveat and add in more costs to cover the risk of not having the exact drawings done.
    A few things to watch out for, getting the buidling physics in a loft is really important, its is very easy to end up with very energy inefficient lot conversions, very cold in winter and very hot in summer through poor insulation and poor ventilation and heating. This happens so often. More insulation means warmer in winter and cooler in summer and explore wood fibre and other natural insulations rather than glass fibre and rock wool and PIR, there is growing concern in the industry.
    Also assuming a bathroom may be up there also means really exploring your water pressure too and shower and using an aerator helps to reduce water flow but feel powerful for example.
    Await your response and where are you based?
  • Clifford Burns
    February 1, 2025 at 11:48 am
    Now that’s a detailed reply.
    I am also on that track.
    I’ve found an Architect and drawings will be finalised by the end of this week.
  • Ian Darke
    February 6, 2025 at 11:06 am
    The best thing you can do is approach a near by neighbour. Someone who has had the job done.
    Have a look around your street and ask if you can have a look at their loft conversion.
    They will be able to tell you how long it took. Costs of the job and who they used for the work.
    I’d have no problem speaking with someone if they approached me at my house.
  • James Butler
    March 17, 2025 at 5:59 am
    You may be eligible for free insulation scheme under ECO4 scheme funded by Uk Government.
  • Natalie S.
    October 23, 2025 at 11:58 am
    Hi Mia,
    Getting started on a loft conversion can feel tricky, but once you organize it step by step, it becomes much clearer.
    <strong data-start=”208″ data-end=”217″>First, get your plan 100% clear — how you’ll use the space, head height, and whether you want a bathroom or dormer.
    <strong data-start=”331″ data-end=”339″>Next, talk to an architect or architectural technologist for design and planning advice, and a structural engineer if beams or roof changes are needed. Then you’ll need a general builder to carry out the work and manage trades like electricians and plumbers.
    <strong data-start=”597″ data-end=”606″>Costs vary widely, but a basic Velux-style conversion often starts around £25,000, while a dormer or hip-to-gable type can reach £45,000–£60,000 depending on finish and space.
    Before starting, gather quotes, confirm building regulations, and keep a 10–15% contingency in your budget.
    Having clear drawings and a defined scope helps you get accurate quotes and avoid stress later.
  • Tim Miller
    November 18, 2025 at 4:49 pm
    Getting started is always the hardest bit because there are a few different professionals involved and it’s not always obvious who does what. The usual route is to speak to either an architect or a loft-conversion company first.
    They’ll sketch out what’s possible in your house, explain the staircase options and tell you whether you need things like party wall agreements or planning. A structural engineer then does the calculations once you’ve agreed on a layout.
    For early research, it really helps to get a feel for rough costs so you’re not going in blind. Cost-based sites like HomeOwners Alliance, FMB and MyJobQuote are good for ballpark figures.
    I’d also look at the loft cost breakdown on LoftCompare, which is very clear and gives you typical price ranges for Velux, dormer and mansard conversions:
    http://www.loftcompare.co.uk/loft-conversion-costs
    Or check out these guys
    too: https://resi.co.uk/advice/loft-conversions/loft-conversion-cost
    Once you’ve read a couple of those guides, you’ll have a much better idea of which bits are standard, which bits need specialists and how to line things up in the right order. After that, get two or three companies out to quote so you can compare what they’re including.
