Forums Forums SOLAR FORUM UK I have 4 solar quotes and would appreciate some advice…
  • I have 4 solar quotes and would appreciate some advice…
    Posted by George Brown on January 25, 2025 at 1:55 pm
    Any advice appreciated, have 4 comparable quotes what would you consider the best spec/quote for the job. Knowledge on solar is limited!
    Panels: Trina Vertex 5+ 430W x17
    Inverter: GivEnergy 11kw 3ph Hybrid
    Battery: GivEnergy 3.4kwh Lifepo4 x6
    £17,600
    Panels: Jinko Tiger 430w x17
    Inverter: Growatt MOD 10000 TL3-X 3ph
    Battery: Solax Triple 5.8kwh x 2
    £19,770
    Inverter: Fox ESS H3 10kwh Hybrid
    Battery: Fox ESS Ep11 10.36kwh
    £17,412.37
    Panels: JASolar 405w x 24
    Inverter: Solis 10Kw 5G inverter
    Battery: Pylon Force 10.66kwh
    £17,954
    Emily Wilson replied 10 months, 1 week ago 6 Members · 5 Replies
  • 5 Replies
  • George Anderson
    January 25, 2025 at 1:56 pm
    They are all very similar tbf. I’d probably avoid the JA 405s personally.
    I’d go with the Giv or Fox option personally. I have no idea why a growatt inverter would have a premium price over the fox or giv.
  • Harry Johnson
    January 25, 2025 at 1:57 pm
    I’d avoid mix and matching equipment, while technically it’s fine, if you ever have a problem it will become a blame game between inverter company and battery company with you lost in the middle.
    Personally I would opt for option 1 with the Giv set up.
    Make sure installer is MCS and check the register before you pay deposit.
    Which – trusted traders, is also a good place as all reviews are verified and due diligence has been done by which.
  • Henry Smith
    January 25, 2025 at 1:58 pm
    From my personal experience : I’ve installed Trina Vertex and Solis myself. Couldn’t do any better. Solis can work with ANY battery even DIY.
  • Edward Jackson
    January 25, 2025 at 1:59 pm
    Pick the company with the best reputation and longevity. After sales is a must. Most people just go on the price and then find they have no support further down the road.
    You need a battery with at least a 5kW output, any less and you will not cover some normal house use, I always suggest minimum battery capacity of 10kW as well.
  • Emily Wilson
    January 25, 2025 at 2:00 pm
    Whoever you use make sure they as local as possible, leave the national firms alone, if something goes wrong you’ll never get them back
